Aller au contenu principal
Xbox Series S Plastic Case Replacement
Ce dont vous avez besoin
  1. Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: étape 1, image 1 de 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: étape 1, image 2 de 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: étape 1, image 3 de 3
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Plastic Case Replacement, Remove the back panel screws: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Plastic Case Replacement, Remove the bottom panel: étape 3, image 1 de 3 Xbox Series S Plastic Case Replacement, Remove the bottom panel: étape 3, image 2 de 3 Xbox Series S Plastic Case Replacement, Remove the bottom panel: étape 3, image 3 de 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Plastic Case Replacement, Remove the plastic case screws: étape 4, image 1 de 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Plastic Case Replacement, Remove the plastic case: étape 5, image 1 de 3 Xbox Series S Plastic Case Replacement, Remove the plastic case: étape 5, image 2 de 3 Xbox Series S Plastic Case Replacement, Remove the plastic case: étape 5, image 3 de 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Plastic Case Replacement: étape 6, image 1 de 3 Xbox Series S Plastic Case Replacement: étape 6, image 2 de 3 Xbox Series S Plastic Case Replacement: étape 6, image 3 de 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 autres ont terminé cette réparation.
Robert Boyd
Membre depuis le 02/01/21
26 559 Réputation
94 tutoriels rédigés
3 commentaires
Where can i find custom case for the xbox series s?
Joe - Réponse
What about the back plate?
Legitti - Réponse
it says you cant remove it
Pavement Creator - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 46
7 derniers jours : 241
30 derniers jours : 986
Total : 26,805
