Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iMac 27" 2017 RAM Replacement
Ce dont vous avez besoin
  1. iMac 27" 2017 RAM Replacement, Open the RAM door: étape 1, image 1 de 2 iMac 27" 2017 RAM Replacement, Open the RAM door: étape 1, image 2 de 2
    • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
    • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
    Demander à FixBot
    Ajouter un commentaire
  2. iMac 27" 2017 RAM Replacement, Remove the RAM door: étape 2, image 1 de 3 iMac 27" 2017 RAM Replacement, Remove the RAM door: étape 2, image 2 de 3 iMac 27" 2017 RAM Replacement, Remove the RAM door: étape 2, image 3 de 3
    • Pull the RAM access door off the back of the iMac.
    Demander à FixBot
  3. iMac 27" 2017 RAM Replacement, Unlock the RAM tray: étape 3, image 1 de 3 iMac 27" 2017 RAM Replacement, Unlock the RAM tray: étape 3, image 2 de 3 iMac 27" 2017 RAM Replacement, Unlock the RAM tray: étape 3, image 3 de 3
    • The RAM tray is locked into its upright position with two grey tabs.
    • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
    • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
    Demander à FixBot
  4. iMac 27" 2017 RAM Replacement, Remove the RAM: étape 4, image 1 de 3 iMac 27" 2017 RAM Replacement, Remove the RAM: étape 4, image 2 de 3 iMac 27" 2017 RAM Replacement, Remove the RAM: étape 4, image 3 de 3
    • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
    • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
    • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
    • The RAM access door is not symmetrical. If it is not flush on both ends, try putting it in the other way.
    • Re-insert the RAM access door back into its place.
    Demander à FixBot
6 autres ont terminé cette réparation.
Adam O'Camb
Membre depuis le 04/11/15
223 213 Réputation
416 tutoriels rédigés
2 commentaires de tutoriel
Thanks Arthur, I got them
walser1 - Réponse Partager
bom dia, posso trocar a memoria de 2444MHZ para 2666MHZ? 3000MHZ ?
MARCELO MIRA - Réponse Partager
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 49
30 derniers jours : 215
Total : 21,229
