I have repaired this metal frame successfully, but it is hard work, and I had to carefully weigh Time v Cost. Cost won, so I bought a new one from this very site. HOWEVER, when there were no time or cost constraints, and simply to DO it, I attempted the repair...
J B Weld.....ummmm NO (I cleaned the metal with MEK, let it flash to air, waited the 5 minutes for the JB to be mixed. 24 hours later, I had made a mold (impression), but I did not repair this satisfactorily.
SuperGlue (3 kinds, all aircraft/model formulations) none worked.
The only thing that actually put the metal frame back together firmly enough to support my battery (hanging) test was welding.
I used a flea market aluminum "welding" rod with the "flux" they included with the kit...
cleaned it with a stainless wire brush (theirs') and heated the weighted and positioned ends so I could
"scrub" the aluminum rod onto the break.
One big glob later. and a lot of luck,
I filed and ground (Dremel) the glob down to merely huge, and it was used in a rebuild and remains "good-to-go"
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
