Aller au contenu principal
APC Back-UPS RS,600 Watts /1000 VA, Entrée 120V / Sortie 120V, Interface Port USB, Hauteur du Rack 2.
Questions au sujet de 5 Voir tout
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
par
Ajouter un commentaire
5 Réponses
Solution retenue
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
Indice 2
Réponse la plus utile
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
Indice 4
2 commentaires:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
par
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
par
- Turn off the unit
Good Luck...
Indice 2
1 commentaire:
Thank you but I replaced the old ups with a new one. Yours sincerely.
par
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
Indice 1
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
Indice 0
Ajouter une réponse
Roberto sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 23
30 derniers jours : 106
Total : 36,745
