Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
Questions au sujet de 2507 Voir tout
iPhone 5 Rear Panel Replaceability
How repairable is the rear case of the iPhone 5? And what is the cost? I know that it is virtually shatterproof, but it also scratches significantly easier than the glass panel of previous models. If the rear panel is expensive and difficult to replace I will probably use a case, but if it is relatively inexpensive and easy to repair then I would rather take on some scratches and put my money toward an extra rear panel. What do you think?
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Solution retenue
The phone starts with the aluminum unibody (rear case), and every single component is then placed and layered into it. Replacing the rear case literally involves removing every component from the phone. Add that to the fact that an OEM quality rear case with a sapphire camera lens cover won't be cheap, and you've got yourself a time-consuming, risky, and costly repair. Spend $30 or $40 on a good case if the scratches are going to bother you that much.
Indice 2
I replaced one. It will cost about $100 and more than 2 hours. But it works
Indice 1
Ajouter une réponse
dbloxjunk sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,173
