Aller au contenu principal
Le premier modèle d'iPhone, modèle A1203 avec 4 ou 8 Go de stockage, et coque en aluminum. Les réparations sont souvent basées sur le principe du levier et peuvent demander de la soudure quelques fois.
224 questions Voir tout
new battery but only 61% of power
hi
I changed my iPhone 2g battery today. After this process I was happy about a running iPhone :)
The only problem is that my battery still says that it has 61% of power. I tried to charge with the power supply and with usb on my mac, but it keep still standing up to 61%
do i have to do a complete restore to get the 100% of charge? or is there any way else to fix it?
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
One thing you may try, especially if the battery is new (as you said) is to let it run down all the way so it is completely empty and will not run, and then throw it on a charger and leave it alone until it hits (hopefully) 100%.
It's worth a shot.
EDIT: Another thing to try is resetting the phone settings. Other threads seem to have come across this as a solution when a physical battery calibration doesn't do the trick.
Indice 1
Ajouter une réponse
Kay Kahl sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 1,088
