iMac Doesn't turn on,,,DEAD power supply or logic board?
I got this 2Ghz iMac Intel 17" Late 2006. It shows no sign of life what so ever. When the power button is pressed nothing happens. Nothing on the screen, no fans spinning up, no lights. Nothing. It just happened out of nowhere. One day it was ok, the next it wouldn't power on.
I'm pretty good with PCs, not so much with Macs, but If the same principles apply, I would suspect a bad power supply. I've checked to make sure the outlet where it is plugged in works.
What can I check or do to get this computer working again? Is the power supply the only suspect in this case?
When it comes to PCs, I've been able to test the power supply using a multimeter. Can I test the power supply on this iMac? I've stripped it down to the guts, removing the power supply, and hard drive. On the power supply I only see two wires coming out of it. Very different from a PC's power supply unit where it has many different wires.
Also, one thing I am concerned about is the integrity of the hard drive. It is a Western Digital with SATA interface. I was wondering if I can connect the hard drive to my other computer, a PC running Windows 7, via an external enclosure to test it and confirm that all the pics, videos, and documents are still there.
Info gathered so far:
I reinstalled the PSU and plugged in the power cord. Since I have the iMac taken apart where I can see the logic board, I noticed a green LED light on the logic board come on. It is labeled as "LED601". When I press the power button on the back of the iMac, another LED comes on, this one labeled "LED602". Also, on the right speaker there is a light that also comes on when I pressed the power button. This light has a light blue color to it. I also noticed that the fan right below the Super Drive tried to spin, but it didn't actually spin.
Please help
Update
Received the power supply in the mail today. Installed it, put everything back together, and iMac turned on. Glad it wasn't the logic board.
1 commentaire
Did you follow the iFixIt guides on the correct way to disassemble your iMac?
par Dan
