Aller au contenu principal
Pour réparer ensemble - Je crée un compte
En 2012, Sony Entertainment annonce la sortie d'une nouvelle version de sa console Playstation 3 de 2006. La nouvelle console s'appelle Playstation 3 Super Slim et s'identifie par le numéro de modèle CECH-4000. La PlayStation 3 Super Slim (CECH400x) est la troisième version de la console de jeux vidéo PS3 produite par Sony Computer Entertainment. Elle est commercialisée le 25 octobre 2012.
How do I upgrade the memory on the 12GB model?
A friend of mine has a 12GB model of this device and I understand that this does not contain a hard drive. How do I add an internal hard drive so that I can increase the memory?
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
well this answer technically and factually incorrect
par
Ajouter un commentaire
11 Réponses
Solution retenue
We don't have a guide, but our teardown shows you where the hard drive bay is. Any 2.5" laptop hard drive should plug-and-play just fine.
Indice 3
Hi Alex. You or your friend must buy HDD bracket. This operation is easy and will not cancel warranty. All necessary screws and instructions will be in the package. PS3 also can work with 1Tb HDD. Package looks like this: http://community.us.playstation.com/t5/i...
Indice 2
1 commentaire:
no you need a double HDD bracket or a 20 HDD bracket.
par
No1 liked Sony's idea creating a ps3 with flash memory (12gb) You can use and external hard drive but it will cost u money so...
I recommend u too use the cheapest bracket which is the 40gb i think . It's good for storing game file directories but not meant for huge games but still worth it .Dont worry if u have a low hdd on ur ps3. Other method is: Instead of bracket, u can use an 2.5 inch SATA drive, mostly found on pc or laptops,they vary accrording to their RPM. 5400 rpm is enough for ps3. For further help, use youtube
Indice 2
1 commentaire:
no acually a 50 gb bracket is the cheapest
par
How do I upgrade to HDD for more free space on PlayStation 3
Indice 1
1 commentaire:
you need to get a 20 gb hard drive and a new HDD bracket
par
As i said , you don't have to use SATA everytime u want to upgrade your hdd. U can use their memory drive and if it doesnt fit te ps3 hdd place , u have to use a kind of credit card(expired) or smth like that.i used my old pc storage and succeeded. Good luck!
Indice 1
1 commentaire:
yeah SATA is acually being replaced
par
Can use any 2.5" sata hdd also you need a hdd slim cage... find both on ebay!
Or you can use a bit of card top and bottom to hold the hdd in place. You must secure the drive so it cant move about.
Otherwise the hdd kind of floats held only by the sata port... not recommended as a slightest move of the ps3 can dislodge it!
See my vid about 3 minute mark. Whear i do this on a PS3 slim for an example.
https://m.youtube.com/watch?v=eUpZWiXCoF...
Indice 1
A HDD 40 gb hard drive or disc is still not what you need you need a 20 gb hard drive or a new HDD but a new HDD is more money
Indice 0
I got a 160GB hard drive for 20 dollars so now I'll have 172 GB so altogether I put 85 dollars into my PS3 not bad and the games are cheap too there is a lot u can't play on the PS4 without streaming them for a
Indice 0
Same Hard drive as the fat PS3? or PS4?
Indice 0
Yes, the hard disk drives are the same both on the PS3 and PS4. Also, the 2.5" SSD can be installed. But for real, there is very small difference in the game loading.
Indice 0
From what I know, it helps to separate storage from memory because they are different things. If the 12GB model has no internal hard drive, you usually cannot increase its RAM by installing one. In many devices of this type, the memory is fixed to the motherboard, while storage upgrades depend on whether the hardware includes a compatible drive connector or expansion slot. It is also worth checking the cache memory specifications, as they affect performance differently from RAM or storage. I would verify the exact model and service manual before purchasing any upgrades.
Indice 0
1 commentaire:
Sorry, but the 12GB has nothing to do with the ram memory. You have 2 different type of models out there. The 12GB onboard flash storage memory model and the 500GB HDD one.
So, as already is mentioned above, you can upgrade the 12GB flash storage model with a HDD, but you need the HDD bracket that is suitable for the PS3 Super Slim. Whenever you decided to buy that, you can put in every 2,5 inch HDD/SSD you want and upgrade the storage.
Whenever, you have bought the 500GB one, you will not have the onboard flash storage memory and you can either upgrade/replace the HDD.
par
Ajouter une réponse
Alex Blower sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 33
Total : 65,886
