Aller au contenu principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 questions Voir tout
laptop says plugged in but not charging.
This problem started 3 months ago, all I had to do was unplug it and then plug it back in and it would charge fine. Now nothing works it just says "pluged in (not charging)" now.
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
Use this : Dell AC Adapter LA90PM130
par
Ajouter un commentaire
2 Réponses
Solution retenue
This could be an indication that the battery wont hold a charge. Might need to replace the battery
Indice 0
It seems like you battery is expired because usually laptop`s battery last for 1 to 2 in normal form. So if your laptop is a year or two older then you would defiantly need to replace the batter and make sure to order the proper OEM replacement battery because other aftermarket ones wont give you very good output.
Indice 0
1 commentaire:
I was change a battery last week but still plugged in not charging
par
Ajouter une réponse
Andy Lamb sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 6
Total : 1,590
