Aller au contenu principal
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Questions au sujet de 50 Voir tout
dropped ipad, bent the alluminium case on the volume bottom
I've just dropped my ipad and the alluminium case bent on the volume button, i cant use the volume button and it stuck inside (volume square is frozen on the sceen). Is it possible to open the ipad and reshape the allumium case or is it too risky?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
Hi Lou,
As you have probably noted, there is no screw to open the iPad 2 and in fact it make opening this iDevice much more complicate that an iPhone for example.
This is the reason why all iPad 2 guides are marked "Very difficult"!
I wouldn't say it is too risky, it depends on you, your skills and probably also your tools. If you want to make a good job you will have to use the good tools. Look at this iOpener at least!
  • If you decide to access the volume button hole from inside the rear case, the minimum require disassemble is the display. Look at this guide so you will have a better view on what you would have to do.
  • Once you will have the screen out, you will have a better view if further dis-assembly is required. Any further dis-assembly should be piece of cake after what you've done just before!
  • Also remember that you're gonna have to re-install the screen with new adhesive strips after that. (New adhesive strips available here.)
Let us know what is your decision, and good luck!
Image iPad 2 Adhesive Strips
Produit
$6.99
Image iOpener
Produit
iOpener
$19.99
Image iPad 2 CDMA Écran LCD
Tutoriel
Remplacement de l'écran LCD de l'iPad 2 CDMA
Difficulté :
Très difficile
Image iPad 2 CDMA Bandes adhésives du panneau frontal
Tutoriel
Remplacement des bandes adhésives de panneau frontal de l'iPad 2 CDMA
Difficulté :
Modérée
Indice 2
If the case is bent in the volume control area you can just use pliers to unbend the case. Be careful and use a cloth pad to avoid scaring the case. In my case (pun intended) the thin aluminum above the cutout part of the case was bent and Apple wanted almost as much as a new one to repair it.
Indice 0
Ajouter une réponse
Lou sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 5,670
