Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Un dispositif sanitaire pour l'évacuation des déchets humains. Pas besoin de plombier ! Réparer des toilettes est bien plus simple que ce que beaucoup de gens imaginent.
toilet bowl doesnt hold water
toilet bowl doesnt hold water, it flushes fine and wax ring doesnt leak. Tank fills and flushes but water doesnt stay in bowl
Répondu ! Afficher la réponse J'ai le même problème
Indice 9
2 commentaires
I installed a Kohler 1323429 toilet. Bowl is slowly losing water.
par
I installed a brand new toilet, but when the water is off you can hear water draining from the toilet, what is causing that, the toilet,tub,sink,is all one drain
par
Ajouter un commentaire
3 Réponses
Solution retenue
tom hogg, of course, this may be a difficult question to answer since we do not know the make and model of your toilet ;-) Remember that the water stays at a given level because of the u-bend, which is called a trap, within the porcelain of your toilet. The shape of the bend will determine the height of the water level. So, it is possible that that there is a crack in the trap of the toilet its self and the water is slowly running down the drain (lucky you ). The other, and actually more common issue can be a clogged or improperly installed vent. One way you can check for a plugged vent by flushing the toilet, When the toilet then fills and the tank shuts off the water to the toilet, turn on the hot and cold water on the closest fixture to the toilet, most likely your sink or the tub. If the water level moves in the toilet you have a clogged vent. The change in the level will happen within minutes. Check the vent where it sticks up through the roof and look for obstructions. You can use a snake to snake out the vent stack or flush it with a garden hose (could be messy). The other problem can be a partially clogged downstream drain line. That could siphon the water out of the toilet. give your system a good cleaning with a snake and see what happens. Hope this helps, good luck.
Indice 11
4 commentaires:
If there is a partial clog in the vent pipe, Why would running the water nearest the toilet impact the water level in the toilet?
par
@tryinghard syphoning effect from the other drain if it connects to the same vent stack. It would sypon it out as the other drain empties to equal the pressure.
par
Much appreciated.
par
@oldturkey03 good answer. It does seem to be more of a venting issue as the water moves in the bowl like it is shipboard with a rocking boat. Thank you for the answer.
par
You are screwed , it cannot be fixed unless you replace your entire plumbing system pipes , fixtures, valves, water heater , washing machine , meter , spigots and line from meter to house.
Indice 1
1 commentaire:
Your troll game is weak af, sir 😂
par
Actually it had to do with the fact we had a 2-hour power outage and the vent must have been affected.
I called a plumber, he flushed it about 4 more times, and voila, the water is now in there and stays.
Who knows why it wouldn't stay at first?
Indice 0
Ajouter une réponse
tom hogg sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 31
7 derniers jours : 208
30 derniers jours : 1,072
Total : 313,170
