Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
Mac mini not powering on
Hi
I've got a mac mini mid 2011 from ebay and it doesn't power on. I'm testing the power supply and following the guide, I should have 12V checking the two outer pins. When the power cable is connected I got that voltage but as the time pass, the voltage decrease going to 0V.
Is this behaviour normal ? or is the power supply defective ?
for instance, the power supply installed is an oem from delta electronics 614-0503, not a 661-6085.
Has anybody have experience with those power supllies ?
thanks
Daniele
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
The power supply should be Part Number: 661-6085. But the 614-0503 is also listed for this machine: http://www.techrepublic.com/photos/crack...
It's very common to have more than one parts supplier. I think either one will work for your replacement.
Indice 3
1 commentaire:
thank you for the answer.
But Is power supply's behaviour normal ? or is it defective ?
If tried even to put a resistor in order to have a load on the output and the voltage decreased faster.
par
The behavior indicates a failed power supply; the supplied voltage must not sag too much. Probably a bad capacitor or something wrong with the feedback circuit in the PS; Just replace it
Indice 0
Ajouter une réponse
Daniele Acquadro sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,102
