Aller au contenu principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 questions Voir tout
Question close
s2 not charging battery to 100%
S2 battery holder jack inside battery chamber.. Showing open circuit voltage..4.16only..no over heating any where...i hve already replaced usb flex ..bt same problem ...
On charging ..while m running heavy application ..battery goes down
Max battery charge voltage(closed circuit)4.012
Battery charger is ok... Nd delivering 5 volt on mother board
S2 model is i9100G
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
I do believe that if you push these these phones hard enough, you can actually drain the battery even if you have it plugged in and "charging." I know one of my buddies did it downloading and gaming at the same one before. 4.16volts is kinda high for a 3.7 volt battery though. I've seen mine max at roughly 4.02 volts, but that's on a Galaxy S2 Skyrocket.
Indice 1
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 4
Total : 3,724
