oil light comes on after oil has been changed
Sorry, I need to know what to do when the oil light comes on, after oil is changed.(Not the brake light)
Liz Morton, try this:"
1999-2003
Turn the ignition to run (one position before starting engine).
Press the RESET button (in fuse panel block inside driver side door)and release. The CHANGE OIL indicator will start flashing.
Press and hold the RESET button until audible chime is heard and then release.
Turn the ignition off and then start the engine to verify the indicator has been reset.
2004-2005
Immediately after Step 1 press and release the gas pedal 3 times within 5 seconds. The reset is complete when you hear the chimes and the CHANGE OIL light goes out.
Turn the ignition off and then start the engine to verify the indicator has been reset." Hope this helps, good luck.
oldturkey03 your second method for 2004-2005 worked for my 2000 Pontiac Grand AM GT 2D Coupe(3400 SFI engine), I was low on oil yesterday afternoon added a quart went to work today and after work seen my Change Oil light was on.. before even leaving my jobsite I looked this up tried it and worked right away!
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 40
Total : 3,049
2 commentaires
Have you checked to make sure that you do have enough oil? Or you mean the light comes on all the time and stays on, even with enough oil? What engine, what transmission and what year is your Pontiac?
par oldturkey03
Liz Morton, you mean this is the wrong question ;-) dash brake light comes on after oil change, what do u do?
par oldturkey03
