Aller au contenu principal
Le Samsung Galaxy S4, modèle i9505, dispose d'une caméra arrière de 13 mégapixels et d'un écran de 5 pouces et 1080 pixels.
523 questions Voir tout
Galaxy s4 Digitizer is Touching LCD
Hi,
I just replaced the digitizer on my S4 and after a few hours I can see a bubble being created because it is touching the LCD.
During the install I used 3m double sided tape to make a border. Should I double up the tape?
Thanks Everyone
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
5 Réponses
Solution retenue
yes you should and if that doesnt help triple it
Indice 1
Its easy to damage your Galaxy S4 while trying to repair it yourself. I sent mine for repair and they do a great job. They fixed my S3 and my S4 and I could'nt be happier with the price and service they gave me!
Thank you ifixit.com for leading me in the right direction for my repairs! This site ROCKS!!!
Indice 0
I always put one row of 2mm tape on the lcd face along the bottom, top and sides to form a dust proof barrier. I had same problem with adhesive tape they sell for the phone. Since I started doing it this way I have not had the "Newton ring" you speak of. This can also be solved by using loca to reassemble. The s4 seems to have a tighter tolerance than the s3.
Indice 0
Hello my digitizer needs fixed also does anyone know where I can get it fixed n how much.. didnt hav my samsung galaxy s4 active long either
Indice 0
The only true way to fix this is to use Liquid Optically Clear Adhesive Or LOCA and that will ensure that there is no air gap to allow the top glass to touch the lcd/digitizer on your Galaxy S4. Even if you double up the tape, eventually the tape will get so smashed down and then glass will start to bow that the glass will touch the lcd again. Not guaranteeing that will happen but most certainly can.
Here is a video of a tech applying liquid optically clear adhesive / LOCA to an S4 LCD.
Indice 0
Ajouter une réponse
Manny sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 9,272
