Chris, when a computer is not functioning, the first step is to remove all extraneous parts that are cluttering the big picture and see if anything changes with those parts removed. First, I would make sure your AC adapter is functional with another computer...until you have seen it working, you don't have a known-good AC adapter. Next, I'd take off the lower casing, remove the hard drive, disconnect the battery, and remove one of the memory modules (as well as test the RAM slots as Dan suggested above). Take note of any dust, and blow it out with a can of compressed air, since dust conducts electricity and can be responsible for your system getting "zapped". See if you get a light on the AC at this point. If not, I would let the computer sit overnight with both AC and battery disconnected, because sometimes a laptop will take on a "bad charge", and it will not work again until this charge is allowed to dissipate. Also, repeat the RAM slot test occasionally.
If you do finally get a light on the AC adapter but the laptop won't power on, the next step is to try to jump the logic board by bridging the power-on pads with a metal object. This is because the power button/keyboard assembly in unibodies is problematic and very susceptible to liquid damage, and therefore it's necessary to try powering on the board without it. Often the board is good, and the laptop is simply not capable of powering itself on because the power button's connection to the logic board has gotten fried.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
6 commentaires
Did you get it wet at sometime? Or, did it get banged (dented)? While it may have worked just afterwards the damage could take awhile to take hold.
par Dan
It has never been wet or dented. It has, however, often been in hot environments.
par Chris
How hot? Beyond what you could stand. If so you could have damaged something.
par Dan
My office's air conditioning broke right as summer hit. So, hot! If its heat related, what's the most likely culprit?
par Chris
If the sun was beating down on it and the system was running in this elevated condition then the heat could have caused a premature failure of some component. The battery pack and the LCD are the most sensitive to extreme heat or cold.
par Dan
Afficher 1 commentaire en plus
