Aller au contenu principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 questions Voir tout
Can't get out ,what's the best solution to put SSD drive
My Imac is from Early 2008, Intel based CPU.
I am consulting allready some guides for change my HD by a SSD , Is it possible in this model ? I read somewhere that the SSD can not mounted even with a adapter because the cables are too short in the Imac.
Can someone guide top a good solution. I am able to change or remove the optical drive and put the original HD in the optical bay . And put a ssd in the original place where the HD was before. So is this possible and what do I need to buy from hardware (except the SSD)
Thanks For help
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
3 Réponses
Solution retenue
Not sure I follow your comment of the cables being to short here. If you do a direct swap out HD for SSD there is no cable issues as both use SATA and have the connections in the same location (using a SSD that is the same size as your HD). If you go with a 2.5 SSD then you can have some issues as the SSD SATA port is located in a slightly different place.
In any case I would use a dual drive setup - keeping the HD for data storage and using the SSD for OS & App storage. I wouldn't setup a Fusion drive here as the I/O of the drives is not matched (you'll have access & speed problems trust me!)
Follow this IFIXIT guide Dual HD (or SSD) install. In this case you're using a SSD Vs an HD as the guide was written with the idea of adding a second HD.
As to what to use for a SSD your systems SATA connection is only SATA I (1.5Gb/s) so you should stick with a SATA I (1.5Gb/s) or SATA II (3.0Gb/s) SSD for your primary drive, then moving your HD to the PATA carrier (SATA to PATA). Getting a SATA III SSD could create problems and is a waste of money as your system can't leverage the higher I/O speed.
Indice 3
Asked & Answered
If this Answer is helpful please remember to return and mark it Accepted.
Indice 1
1 commentaire:
Thanks for clarifying so detailed , really accepted , and know I think to go to add a SSD in combi with HD
Thanks
par
According to everymac.com the early 2008's used SATA II not SATA I
http://www.everymac.com/systems/apple/im...
Indice 0
Ajouter une réponse
Dirk sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 5
Total : 487
