Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mise à niveau de la Nintendo Game Boy Advance, l'Advance SP est sortie, en Amérique du Nord, le 23 mars 2004 avec une structure carrée et un design à coque.
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
Répondre à cette question J'ai le même problème
Indice 7
5 commentaires:
Same thing for me, but the battery replacement didn't work
par
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
par
Same problem
par
Do a bridge on the F2 fuse.
par
i have that same problem
par
Ajouter un commentaire
6 Réponses
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
Indice 0
1 commentaire:
Already did. No help
par
I think you should bye a new gameBoy Advanced SP
Indice 0
Indice 0
All you need is a new battery :)
Indice 0
I had the same problem. It was because of the battery. Not the charger, not the cable, not the GBA itself.
I solved it by plugging an unplugging the cable several times. I slowly noticed a little increase the time the orange light was on (not reaching a second). Then it stayed on and charged.
My guess is that the battery was in a deep-dicharge state and that cycling refreshed the charging protection and kickstarted it.
Indice 0
Hi. There is a solution that you can find on You tube however I will just say it here. If the battery isn't swelling, follow these steps as it generally has a success rate of 60%. All you got to do is just plug in the power cable and then unplug (Wait around a second before unplugging it). Then, just keep on plugging in the power cable, wait a second and then unplug it until the light comes on (If it doesn't turn on after around 20 minutes, you may have to replace the battery). After the light stays on, leave it for a day. By the way this happens usually after the GBA SP being in storage for a while (Probably the case with your friends GBA SP) and the battery voltage decreases to a very low level. If you don't want to do this, just follow the tutorial oldturkey03 provided. Good luck!
Indice 0
Ajouter une réponse
Tommy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 31
Total : 13,135
