Aller au contenu principal
Repair information for the Bose QuietComfort 2 acoustic noise-canceling headphones. Released in 2003. Model number: QC2.
Questions au sujet de 21 Voir tout
How to fix when battery corroded
Battery corroded in my Bose Quietcomfort 2 and now they won't work. Called Bose, no help. Attempted to clean the connectors, still won't work. Any suggestions, please help!!!
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
2 commentaires
This recommendation absolutely worked for me. You must try this before you take more invasive measures.
par
The vinegar worked for me. Ive had my Bose headset quite a while and didn’t want to part with it. I cleaned with the vinegar initially a week ago without success. Tried it just now and bam—green light. Thank you.
par
Ajouter un commentaire
3 Réponses
Solution retenue
My favorite method to fix this is using a q-tip with baking soda and water. I usually just moisten the q-tip and then dip it in the baking soda then i scrub away the battery acid.
Indice 6
5 commentaires:
I'm sorry. What is a q-tip with baking soda and water? Thanks!
par
Thank You. I tried the alcohol Q-tips and it cleaned the mess but no contact was made. I used the Q-tip with baking soda and it worked .
par
It worked. Thank you
par
q-tip and white vinegar worked for me.
par
I also used the Q-tip with baking soda and it worked. Thanks for posting this!
par
Vinegar is supposed to remove alkaline battery corrosion. I used a q-tip and vinegar to restore my Bose QC2s, and then was careful to never store them with the battery inside. Unfortunately, despite this, they developed the same problem again (not turning on when a good battery is inserted), and this time vinegar has not been able to make them work.
I can barely see inside, but the anode at the bottom ("-" side) looks corroded brown rather than green. Perhaps a different issue. I can't believe how fragile these super expensive headphones have been. I'll try more drastic measures to clean inside there...not much to lose at this point.
Indice 6
11 commentaires:
it worked !! the Qtip submerged in vinegar worked. clean the battery compartment real good! Thank you thank you. I was going to return my headset but now I am going to keep it.
par
The light should turn Green..on QC 15
par
This worked for me- Bose headphones fixed. Thanks so much!!
par
Worked for me as well. thank you very much
par
this worked for me, after cleaning; insert a battery and if doesnt turn on give the headphone a little tap a few times it should turn on.
par
Voir 6 commentaires en plus
Hi dcar,
I would suggest to use fine sand paper and use it on the corroded metal battery holder part until you get it to look like metal again. Then use alcohol of some sort to clean it off. To avoid getting dust inside tape off any holes from battery compartment to the product before sanding.
best of luck.
Indice 0
Ajouter une réponse
dcar2004 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 29
30 derniers jours : 169
Total : 22,225
