Aller au contenu principal
Processeur 1.4GHz ou 1.6GHz, SSD de 64 Go or 128 Go.
20 questions Voir tout
Placement order of diffuser sheets?
I'm replacing the screen on a friend's MBA (A1370). Upon removing the broken LCD from the bezel, The 3 sheets of plastic behind it fell out and spread on the floor. Is there a particular order these must be put back in? I'm guessing they must have an order of some sort. Otherwise it will be hit and miss, Trial and error.
Thanks in advance.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
its a very difficult one to describe in words, but the white backing sheet is obviously first, then the thickest plastic sheet lines up with the LED strip at the bottom... then the last few need to be put in order as well. The one with a darker shade, and an almost matte finish is the last one, so the more metallic reflective one goes in-between the thicker one and the last one...
i hope this helps.
Indice 1
2 commentaires:
I've got the same issue. I can't quite understand what order they go in. Can somebody help me with front to back placement - front being closest to the screen? Thanks.
par
Indeed this seems there are only 4 components but my kit came with 5 sheets. Can you please help us figure this out?
par
Ajouter une réponse
Djdat sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 3,187
