Aller au contenu principal
An affordable Windows phone by Nokia, released April 2013.
Questions au sujet de 82 Voir tout
How can I fix my broken power button?
Recently my power button had stuffed up and everytime i use it i have to take the case out and use my fingernails to press it as hard as i can to turn it on.
Répondre à cette question J'ai le même problème
Indice 10
5 commentaires
I have the same problem
par
Omg its works I can't believe this thanks sooooo very much
par
I
have had this problem for a while
par
Thank you! This totally worked.
par
This worked. Thanks so much
par
Ajouter un commentaire
10 Réponses
Réponse la plus utile
Step by step video guide. Fixed in one minute with scissors and a pill blister pack. http://m.youtube.com/watch?v=rLpmEPqE668
Indice 3
1 commentaire:
I hope you get this but it works thanks to u!!! Omg
par
Try This go to http://www.youtube.com/watch?v=BLRlFMVYt...
Indice 1
I confirm Etain's solution: the pill blister trick works perfectly for power & volume buttons. You can try without opening the phone but the best way is to open it (only 8 screws!), so you can position precisely the pill-blister and even secure it to the case using a bit of adhesive tape. My Lumia 520 works like a champ since I fixed it this way months ago. Go to youtube for tutorials!
Indice 1
Well everything goes bad eventually, anyway get a junk phone just like yours and steal the keypad off of it. The spring is broke under the button and or is misaligned (which you could take off and put in another,but very hard to do w/o losing all the parts to the other buttons) And then being very very careful when swapping out ,cause the mini parts are crazy small.
Indice 0
Hello,
Manually repairing the Lumia power button may void your warranty. I'd recommend you to take it to the nearest Nokia Care shop and ask them to repair it for you. Most probably, they won't charge you any money as its still in warranty period.
Hope it may helps you!!
Indice 0
I have the same problem with the power button. It somehow broke off and I am not able to power off the phone causing my battery to drain very quickly. It doesn't pay to have this fixed because the cost of repair is almost the same price as a new phone. The phone still works but who wants a phone that is in constant charge mode! These Lumias are inexpensive enough to buy a new one, that is if you like the phone enough, and I do.
Indice 0
take the battery out of the phone that will turn the phone off for you.
Indice 0
1 commentaire:
My power button is broken I hold
Its not on
And my windows phone app is gonee
Indice 0
my power button is broken any ideas how to fix it? its been broken for awhile now and i cant use it at all. the only way i can turn it on is by the camera or by my charger.
Indice 0
I understand....had the same problem... Bro use the app touch lock..
Indice 0
Ajouter une réponse
Vy Bee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 23
Total : 16,549
