Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire:
I have the same problem as well as not being able to open files. The main answer is that the device is not recognizing the memory card. I can't figure out why. When the tablet starts up, it recognizes the card. The load card option does not work. The card itself has been wiped clean and the tablet says so. I did not wipe it clean. I've removed and reinserted the card. Turned the tablet off and on. Nothing works. I last remember being able to use the camera as well as open pdf and other files before a virus software update.
par CECE FOX
