Aller au contenu principal
Wireless bodypack microphone transmitter.
Backlight not working after display replaced.
I have a SK100 with no backlight, so I tried replacing the display with a replacement direct from Sennheiser and am still having no luck, any suggestions?
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
Did you ever find out how to get it to light back up? I have one with no light. Thanks.
par
Ajouter un commentaire
5 Réponses
Réponse la plus utile
The led is mounted on the main board. It is incredibly small and has to be soldering in the correct orientation for polarity (it is a diode). Look for the triangle mark on the old one for to orient the new one (bottom of triangle points towards bottom of circuit board). Sennheiser part number 522462. Buy 2, because they're so small it's easy to lose the first one!
If you haven't done micro soldering before, good luck. Don't bother unsoldering the old led; just flick it off with an exacto.
Update (12/09/2016)
Sennheiser part number 522462. Bottom of triangle on led points towards bottom of circuit board.
If you haven't done micro soldering before, good luck. Here's some advice:
Add tiny amount of solder to both tabs on circuit board. Hold new led in place with fingernail whilst soldering one side of led in place. Solder other side. Power on beltpack to verify led lights up (you don't need the display board or the rf board ribbon cables connected to verify light).
Indice 1
I've never replaced a display on this item, but I would think that its just an led that is lighting the whole thing as I've seen it commonly in low voltage/modern displays. So look for a surface mount led that is probably on the left or right side of the display and thats probably what is out. If you take pictures of the inside I could maybe direct you more throughly. Thanks
Indice 0
1 commentaire:
I took apart one of my units and still can't see clearly the LED. If anyone has info on this, please share. Thanks!
par
Kind of a weird dude, but he shows were the backlight LED is.
http://youtu.be/dFvN04Woihk
Indice 0
I thing that it have a SMD led
Indice 0
Usually, the backlight diode is placed on the main board, not inside the screen.
Indice 0
1 commentaire:
Usually, the backlight diode is located on the main board.
par
Ajouter une réponse
Ali Dean sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 4,518
