Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
ipad 2 not activating error
This is sorta a follow up to a previous question I had asked.(Replaced digitizer and antennas, still searching..)
None of the previous problems were fixed btw.
So we were instructed to restore the ipad to factory. Now we are getting the:
"Your iPad could not be activated because the activation server is temporarily unavailable. Try connecting your iPad to iTUnes to activate it, or try again in a couple of minutes.
If this problem persists, contact Apple Support at apple.com/support"
What do?
Répondre à cette question J'ai le même problème
Indice 5
1 commentaire
Mine to just after updating to 9.3 - totally bricked my iPad2
par
Ajouter un commentaire
5 Réponses
Réponse la plus utile
I would check for damage in the flex between the main board and the cell service board
Indice 1
1 commentaire:
Hi Jessa,
Vortex's comment below seems to describe the problem I'm having on an iPad 4 which came to me for a battery replacement, it was re-booting every couple minutes.. New battery - No Change, Log files report temperature sensor failure on sensors 0,6 & 1. iPad wont Activate, displays "searching"
Question : if I can find someone that can replace the base band chip, will it function as normal..
Many Thanks
Paul
par
look into log files..
I think baseband temperature sensor fails working causing the part to shutdown, causing the device to reset, and so on
see also Nathan Rakes post, which ist the effect caused by this
Indice 1
I have seen this error many times on iphones with broken baseband chip after water damage or impact damages.
Itunes trying to read device's baseband chip (IMEI number or something like that) to activate the phone.
I guess same thing happening to your ipad CDMA. Baseband chip looks like not functioning.
Reasons
1- If its water damaged try to clean mainboard shortcuts and resolder corroded components.
2- if it has impact damaged, using hot air on the baseband chip may bring the baseband function back. I dont know What temperature and howmany minutes. But you can google for it.
Good luck ...
Indice 0
Hi.
How can i check the flex between board and cell service board?
I mean, if i check bouth sides of the flex i have continuty, but how can i check if the pads are soldered well?
Thanks?
Indice 0
What i want to do with my Ipad 2? Activation server is unavailable?
Indice 0
Ajouter une réponse
Nathan Rakes sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 26
Total : 7,013
