Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
Headphone jack not working
My headphone jack stopped working the other day, so i bought a new lightning dock/headphone jack and installed with no problems, but the headphone jack is still unresponsive to any type of 3.5mm cable. Before you ask, yes i am experienced and i have taken apart and repaired multiple iphone 5, 4, 4s, etc. is there some kind of connector or grounding cable im missing?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
I have the same problem , I ran into this issue when replaced battery by myself . I have also tried replacing charging port assembly but still no sound from headphones . When headphones are plugged in sound comes from speakers . Any help would be appreciated . Thanks
par
Did either of you guys manage to get this resolved as I too have run into the same proble. I have replaced the charging port/headphone assembly. I have reset the phone to factory standards and upgraded it to the latest IOS and it still wont work. The jack just stopped working a week ago, no reason why, no water ingress and the phone always has a protective cover so I have no idea why this has happened. I have checked and rechecked all flexes and connections. The jack is completely dead and does not recognise anything. Thanks in advance!
par
Ajouter un commentaire
4 Réponses
Solution retenue
Could be solved by a restore if files are corrupt just a thought as far as I know there is no grounding clips or anything involving the dock I know the little washers are under the dock but think they are there for spacing
Indice 1
10 commentaires:
Do you mean a factory reset or just restore from a backup?
par
yes just a restore from backup would be grand>
bigmac has a point unclip the connector for the dock on the logic board and see if the pins look damaged
par
After i did this, it worked perfectly, i wish i would have thought of it being a software bug before i threw ten bucks away on a new lightning connector and jack, but hey it's a learning experience. thanks a lot!
par
Happy days glad that resolved it
par
I did the same mistake yesterday baaaaah thanks for this thread
par
Voir 5 commentaires en plus
Same problem a couple of months ago. I would open the phone and check to make sure that there is not bent pins or broken off pieces in the jack.
Indice 1
I also ran into a friends problem with the same thing, ended up being bent pins on the connector on the logic board. if it's that then you'll have to decide how bad you need a headphone jack.
Indice 0
1 commentaire:
Can you point the location of the headphone pins on the logic board?
par
You may want to try this before anything else: I turned my phone off for 10 minutes and then turned it back on. It's working perfectly.
Indice 0
Ajouter une réponse
Michael sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 34
Total : 56,081
