So you’ve got a dead power supply and want to know why. The problem could be something simple, like a blown fuse or loose wire. If so, you might be able to fix the supply for less than $1. This article will outline how to replace a bad power supply fuse, saving you the cost of a whole new supply.
WARNING!
Working on a power supply should not be taken lightly or attempted by someone with little electrical experience. Even when the supply is unplugged, its components can remain charged and SHOCK YOU. If you are in doubt about your abilities, let an experienced repair technician do the work or simply replace the entire power supply.
If you do decide to open a power supply, remember to UNPLUG IT FIRST. Also, DO NOT WEAR A SHORTING BRACELET when working inside a power supply. You do not want to be in the current path of a discharging capacitor. Remember that power supplies are not the high-dollar items they once were and an hour of a tech’s labor is sometimes more than the cost of a new supply. If you do feel confident to work on a power supply, you do so AT YOUR OWN RISK.
A voté
Annuler
Indice
14 commentaires
Has your client contacted Sony to see if a warranty replacement is valid?
par Wade
No she has not, also the warranty seal already been removed. The ps4 was infested with a small colony of roaches by the time I got to it.
par Charles
I think she has bigger issues than the PS4 power supply.
Anywho, researching your question more. Are you referring to the external power brick or the power inlet on the back of the console?
par Wade
I was speaking of the power inlet in the back of the ps4. And no there is no bigger issue I had obtain another ps4 from a friend and switch the PSU and the broken was able to start up.
Dakota I will go ahead and try what you mentioned. I'll post back if I find anything
par Charles
Actually I was referring to the roaches being the bigger issue.
par Wade
Voir 9 commentaires en plus
