How can fix my msi gs70 spacebar?
Whenever I click the spacebar on the outer (left or right) edges I have to click really hard for the laptop to register it as a key press. Sometimes no matter how hard I press or if I even hold down the spacebar key it won't register a click. It works fine if I press near the middle.
17 commentaires
My spacebar,Z, and S key arehavingthe same issues
par Sebastian Olshausen
Steel series doesn't know keyboard engineering. We are the victims. Ideally Space bar should contain 3 sensors [left , mid, right]. We have to suffer because we chose MSI and MSI has chosen Steel series and Steel series has chose an engineer lacking common sense.
par ramaustin1988
http://xoticpcforums.com/showthread.php?...
well known common manufacturer defect
you can mitigate it, but you may not be able to fix it. The mitigation involves opening the case and inserting something to protect the cable where it wraps over the motherboard, passed an unused connector.
par Jaxxed Nesmith
I have the same laptop but in additon to the spacebar my "s" and "z" buttons are not working properlly. They don't work at all or they do more instertion than intendet whcih ressults like this; zzzzz sssss ech. thanksss, zzzero and multiple space touchs.
Any sugestions?
par ozanerkan
I have the same issue, but it only happened when I upgraded to windows 10. Were you able to find a solution?
par Joe Corapi
Voir 12 commentaires en plus
