Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le cinquième téléphone Google Nexus. Annoncé officiellement le 31 octobre 2013, il est doté d'un écran 1080p de 4,95", d'un processeur Snapdragon de 2,26 GHz et du support LTE. Fonctionne sous Android 4.4.2, KITKAT. Fabriqué par LG.
static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
Répondre à cette question J'ai le même problème
Indice 4
2 commentaires:
any solutions ?
par
yes, I fixed it changing the flex usb charge port
par
Ajouter un commentaire
4 Réponses
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
Indice 0
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
Indice 0
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
Indice 0
Have you fixed it...i have same problem...help
Indice 0
1 commentaire:
par
Ajouter une réponse
Alexander Morales Sevilla sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 19
Total : 2,664
