Aller au contenu principal
La Sega Genesis (aussi connue sous le nom de Mega Drive) est la console de jeu vidéo Sega qui a rencontrer le meilleur succès.
35 questions Voir tout
Controller port 1 is iffy at best. How can I fix this?
Recently picked up a free genesis out of the trash. Everything about it works fine, except the first controller port. I'm guessing the pins aren't connecting right, because every controller i've tried with it has the same problem. If anyone has had a similar problem or knows how to fix this please let me know.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
Robby, disassemble it and take a couple of good pictures with your question. That we we could may be check the connector better. You might even find the problem in a cold or fractured solder.
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Hey mate, from what I've read this is a pretty common problem with the Genesis, due its age. The problem is quite often the solder joints on the pins of the port, that connect it to the main board are cracked/broken. This is due to people yanking the controller to disconnect it and ramming it back in, over and over. Luckily, if this is the cause, all you need to do is, open up the Genesis and reflow the solder joints.
This guide should help you opening your Genesis up, and getting the main board out; Remplacement de la carte mère du Sega Genesis
And this should tell you how to reflow the joints (ok its using an amp, but its the same process); Reflowing solder joints on a TEAC GSA-5300 stereo integrated amplifier
Hope it helps you
Image Sega Genesis Carte mère
Tutoriel
Difficulté :
Modérée
15 - 20 minutes
Image TEAC GSA-5300 stereo integrated amplifier
Tutoriel
Difficulté :
Facile
30 minutes
Indice 2
its probably busted or dirty, clean it
Indice 0
You guys are cool to the "T" and my gracias.
Indice 0
Ajouter une réponse
Robby sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 2,555
