Aller au contenu principal
Comment réparer la PlayStation 4, console de jeux télévisés produite par Sony Computer Entertainements, également connue sous le nom de PS4. Annoncée le 20 février 2013 et lancée sur le marché le 15 novembre 2013.
20 questions Voir tout
looking for parts after water damage
Hi, yes I did it, spilled water on my ps4, lots of it...
After dissasembly and cleaning I got it working again except for reading disc's. I need the optical drive controller PCB and a white flex cable. Does anyone knows a ps4 parts supplier? thanks in advance
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
The first thing to keep in mind is that your optical drive PBC is married to your motherboard. If you go and buy another optical drive off of Ebay you will find an error when you try to play any games because the new board is not the one for your motherboard.
With that in mind it is important to try and clean the one you have. The water damage does not look too severe from the pics you posted. Get some 90% + isopropyl alcohol and some q tips and toothbrush. Get the q tip wet with it and rub a generous amount on and around all of the components that are corroded. Then get them good and wet again and take the toothbrush and brush them. This will hopefully get the board working again.
As far as the cable is concerned you can find them on Ebay. There is a wide one and a skinny one so be sure to get the correct one. If you look on the bottom of your board you will see a 010 or 020, as far as I know the wide cable goes with one of those numbers and the skinny cable goes with the other. Be sure to ask the seller which cable it is and maybe even get the measurement just to be sure.
I hope this helps.
Indice 3
3 commentaires:
thank you for your answer! not the one i wanted to hear :-(
I did not know about the relationship between those 2. sounds like the relationship between iphone 5s and the fingerprint homebutton.
the picture was taken before i cleaned it up. after cleaning and checking with microscope i have seen some bad damage.. i wil have to replace the cable anyway because that one is to corroded. replace it and check again.
par
Hopefully it will clean up OK. If not you could solder new components on if you have good soldering skills.
Good luck!
par
Hi, I was wondering if you were able to get the optical drive working again? I have the same problem... Thanks!
par
my plastatin r has water spilled on it is it broke need some help pls?
Indice 0
Ajouter une réponse
ifixshop sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,177
