Aller au contenu principal
La seconde génération d'HTC One - connue sous le nom d'HTC One (M8) - est parue avec un double flash led et la nouvelle surcouche Sense 6 le 25 Mars 2014
Questions au sujet de 201 Voir tout
How do I get the cameras to work again?
I have had this phone for 2 months and both cameras stopped working. I try opening the app and it instantly dies and goes back to the home screen. Also on snapchat the screen shows up black and will not show anything that the lens would be showing.
Répondu ! Afficher la réponse J'ai le même problème
Indice 117
50 commentaires
If there's someone who can help me, my HTC can not take pictures.
par
I have exactly the same problem on my camera and other apps such as instagram,snapchat,whatsapp every app that uses the camera does not let me take a picture, Someone please help it's stressing me out now I've had this problem for almost a month
par
I have a solution that worked for me! Go into Settings - Power - Scroll down to the bottom and uncheck Fast boot - Restart Phone.
par
My sefile is not run. And than dou effect is not work. Now i cant
par
unchecking fast boot worked for me! yay thanks!
par
Voir 45 commentaires en plus
Ajouter un commentaire
20 Réponses
Solution retenue
Hi Buddy
My HTC Camera is not working at all, when i tried to open the camera it open and it shows black screen and then after sometime it comes to home scree.
Can you tell me how to rectify this issue.
Rgds
Sameer
Indice 58
27 commentaires:
Privacy guard... Yeah.. Problem fixed. Thanks :)
par
I didn't find Privacy guard. Where did you find it? The main camera is not working.
par
Its worked!! Thank guys.
par
Bro, I had also this problem. Now it solved
http://www.gogorapid.com/fix-samsung-gal...
par
Voir 22 commentaires en plus
try doing a hard restart . please update the phone software ,
please close all other background app and rsetart the system .
for more follow Guide - steps fix to Phone Camera in phone and try to see if this helps to fix the camera
Indice 12
1 commentaire:
My duo camera stopped working but front camera is still working well please help me .
par
Hey Jacob, here are some things things that I recommend you try:
-Try to 'clear data' under 'camera' in app manager.
-If you're using Lastpass try and do a factory rest.
- If you are using the Lastpass option "Enable fill into apps" and turn it on in accessibility settings then the camera issue might be there. Maybe if you turn it off camera works fine.
-Let me know what happens.
-Hope this helped
Indice 6
1 commentaire:
Please I need help my HTC m8 windows can't open camera
par
SUCCESS!!! first of all thank you for all the suggested solutions. What worked for me? Someone suggested that we should find the apps that use the camera and disable them and VIOLA!!!! that worked for me.
go to settings
then apps
click on each app and scroll to the bottom of each app (each one has to be done individually)
under permissions if the camera is listed you scroll back up and disable the app.
i did not disable messenger though
I VE GOT MY CAMERA BACK!
THANK AGAIN!!!!! HOORAY!
Indice 4
Guys, this is the solution. It worked in my phone.
go to settings then to applications. See which application is using the camera then force stop or disable it. For my case, I forced stop the application called privacy guard and my camera worked perfectly henceforth.
Indice 3
2 commentaires:
how do you determine with app is running your camera
par
par
I turned off phone took battery out blew off any dust put battery back and cover it started to work again
Indice 3
3 commentaires:
you can't take the back off a htc m8 because you have to take the screen out to get to the back of them
par
Not true mine slips off the back it's a bit hard but does open
par
Not sure about m8 my phone is about 3 years old
par
Indice 3
2 commentaires:
no this does not work. stop making false solutions
par
This did work for others, that was rude. Not everyones issue has the same cause.
par
When faced with this problem,
1. Review the last apps you downloaded (Settings>Apps>new downloads)
2. Review to see if it uses the camera for any reason
3. If yes, press the Force stop Bottom
4. If 3 above didn't work, you will have to uninstall the app (s)
I did the above and it turned out an app (Swifty) which I recently downloaded, was the cause of the problem.
Indice 3
2 commentaires:
My HTC M8 is brand new from box but camera not working. I have tried to follow all the instructions here but to no avail. What should I do to this brand new hone?
Phillip
par
If u installed Security 360 just remove this app and restart your mobile phone.
par
Indice 3
I found an answer but I can't explain it just yet. I have a program that allows my home screen to rotate. Whenever I enable that program the camera does not work in portrait mode. Just get a black screen. However the camera does work in landscape mode. If I disable that rotate program the camera works in both portrait and landscape mode. Not sure what caused this to happen just yet. I thought I remember it working just fine at first. My guess is something got borked and it will take some cache clearing or something to resolve fully. As for now my work around is just to disable the screen rotation when I want to use the camera.
Indice 3
What i did is i just stopped the camera ihad!!and i don't know if this is a option for you-but i just downloaded another camera and it's working nicely! Hopefully so can you!!!!----sue
Indice 3
1 commentaire:
I downloaded a new camera but its
still not working
par
I just opened the back on my phone and fiddled and cleaned it a bit where the connection is, when I rebooted it worked again...
Indice 3
I had the same issue even after factory reset. Then I upgraded my software to marshmallow....
The camera is now properly working
Indice 3
UPDATE I got my camera back for a while, it broke again. I'm tired of trying to fix this. I have had no camera for a while now
Indice 2
I don't have no front camera every time I go to the camera and pick the little square box I don't see the selfie sign.
Indice 0
1 commentaire:
Same issue. Can anyone assist please?
par
My camera won't work the message" camera has unexpectedly stopped " shows up did all the above and a factory reset and still doesn't work
Indice 0
1 commentaire:
I suffering from same issue, if you have any solution please share
par
I had a lot of problems with my htc...
I'm disappointed....
And also my camera doesn't work
Indice 0
2 commentaires:
My HTC Desire 530 front facing camera has also stopped working...did all the above...no help...very frustrating ..can someone please help all of us ? HTC peeps?
par
سلام مهسا ، مشکلت رو تو تلگرام بگو راهنماییت کنم
@HaCKeR071
par
Hi
Duo camera is blocked problem after replace camera , plz help me ,
Indice 0
1 commentaire:
HTC makes great phones with too many issues which gives customers tons of migraine. In the long run it's not worth buying.
par
Has anyone contacted HTC and has their phone fixed? I've had my HTC One M9 for 3 days and this has just happened to me.
Indice 0
My camera it's not working
Indice 0
2 commentaires:
My HTC One M8 main camera has stopped working after change of the accumulator battery. Just a black screen. I will try two solutions provided here - turning off "Autorotate" and switching off all the apps that use camera. Will tell you the result soon...
par
My HTC One m8 selfie camera is not working camera app quits to menu when I go to selfie mode and on other apps like snapchat selfie can shows black image
par
Ajouter une réponse
Jacob FUEHRER sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 44
Total : 188,389
