Aller au contenu principal
Model A1318 / 32 or 64 GB capacity
20 questions Voir tout
Dropped in bath and nothing works.
Okay so i dropped i pod touch in a bath of water not very high but enough to cover it. I put in a bowl of uncooked rice for 3day's then i tried to turn it on but nothing happened I've opened it up but there wasn't really any damage then i left it alone for about a year until now i plugged it and gave 3 white blinks then nothing happened.I have it opened now Im thinking about replacing the battery or the logic board. If any information please HELP and let me know thank you. Sincerely Isaac
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Isaac, two things that will make this a very difficult repair. Number 1 is rice. It absolutely does nothing for you. It only delays repair and will increase the chance of corrosion. Number 2 is that you waited a year. This will further increase corrosion damage. You can try and clean it. Use this guide to see how to clean it. It was written for an iPhone 3G but all the points still pertain to your iPod as well. Here are the guides to work on your iPod. After you have it properly cleaned, replace the battery and reevaluate. Water damage is the hardest to diagnose and the most difficult to repair. Hope this helps, good luck.
Indice 1
6 commentaires:
Thank you very much oldturkey03
par
okay so i followed the steps and finished everything's back together but still didn't work can i take this somewhere and could they fix it. oldturkey03
par
depends on where you are located. Try any of the online repair shops. Just be aware that the cost may be higher than the value of your iPod.
par
Tank you very much for you're help.
par
thank sorry i missed spelled that
par
Afficher 1 commentaire en plus
Ajouter une réponse
Isaac sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 41
