Aller au contenu principal
IBM est la société pionnière de l'ordinateur moderne.
20 questions Voir tout
IBM R52 Motherboard ERROR 0271: Check date and time setting
when start my laptop it show this message before access Windows OS.
ERROR 2010: ...hard drive...
and i thinks error with motherboard or bios. please help me.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
3 commentaires
But even if I press F1 the bios is not showing up.
par
my laptop t42 as error is irq not configured-pci serial bus
par
my ibm laptop is not coming up
par
Ajouter un commentaire
3 Réponses
Solution retenue
Error 0271 means you need to run the setup bios utility. I am including a link to a chart of the IBM error codes and their solutions. Hope it helps. Ralph
http://www-307.ibm.com/pc/support/site.w...
Indice 5
Error 0271 probably means your computer lost all power, and lost the time/date. Just press F1 the second anything comes across the display and it should start the BIOS setup utility. Set the date and time, and let the battery charge awhile.
Error 2010 is another pain that I just dealt with. It involves certain machines with a strange bios that looks for firmware that is present in very few hard drives. The easiest way to fix this is to flash the BIOS with an identical bios that doesn't have this error. Here's the link...
http://www.thinkwiki.org/wiki/Problem_wi...
Scroll down until you see "Use unofficial modified BIOS". Before you flash your bios with a new one, make sure you check on the bottom for a sticker that says what type it is, and select the corresponding download link. THIS IS VERY IMPORTANT. The bios updates are VERY specific, and if you choose the wrong one, the update will fail and you have to download the other. Just a small time saver.
*Just a little tip in downloading the file. Sendspace also is covered in ads, so before you click any links, look at what the link it is pointing to actually is. If you're not careful, you might end up getting something you don't want, like adware or malware.*
When you download the .zip file, extract all the files to one folder, and click on the "BIOS" icon. It's pretty distinguished. You don't need to change any of the program's settings, just click "Flash". If you downloaded the right one, then no error messages will appear halfway in, and your computer will auto restart with the new bios.
Either way, neither of these errors actually indicate a huge problem. Error 2010 could be a sign, but generally it's because the hard drive isn't the one that came with the laptop in retail packaging. If you don't feel like taking the time to fix these, you don't need to. Your computer clock might be a little messed up, but that's it. Hope this helped!
Nate
Indice 1
1 commentaire:
Sometimes it happens when you do some bad $@$** after opening the battery or disconnecting it from the port(CMOS battery). Here is what I did.
Pressed enter while starting up, went to temporary boot option, selected windows installed drive(SSD/HDD). luckily it booted up and I had internet connection so no issues for me to automatically set the time of windows. Remember, bios takes the time from windows. so you must have windows installed drive for that. If it helps I will be very happy to know that because I suffered 7 days for ths.
Regards
par
please check bios setting and set the time and then restart computer
Indice 1
Ajouter une réponse
ossuchas sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 44,472
