Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
iPad 2 has poor signal after a few wireless antenna replacements.
I originally replaced the digitizer and antenna, started experiencing issues with poor signal. I assumed that the wireless could've been defective. So, I decided to purchase four wireless antennas. None of them work, same problem. I've did so much research and have had no luck. It's detected the 5Ghz network first, then the 2.4Ghz (When next to the router). I'll connect to it, and I'll see it drop from three bars to two, and maintain the two. I'll began walking away from the router, and problem worsens. I've tried restoring factory settings, and resetting network settings. No luck. I'm in desperate need for some assistance. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
This is still probably and antenna issue---if your four new antennae came from the same batch, they are the same as one.
The WiFi chipset on the board is easy to replace, it is a plug-into-a-socket chipset. Take a look at the board to see the small component that the WiFi antenna plugs into. Damage to the antenna socket could be a possibility here.
Indice 2
Ajouter une réponse
Jerry Mosley sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 1,680
