Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
MacBook Air A1465 Display Replacement
Hi there,
I have the MacBook Air 11in A1465. Bought a few weeks back. I've damaged the display by denting the upper case. A thin 2in dent near the glowing apple. This has not cracked the glass but has damaged the LCD/or one of the back layers. I am thinking I need to replace the entire display and will not get away with just the LCD for this kind of damage, but wanted to seek out opinions first. I can send pictures if that helps.
I found this guide and wanted to know if it would apply to the model I have:
MacBook Air 11" Mid 2013 Display Assembly Replacement
Thanks!
Lee
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
So I found this guide as I posted:
MacBook Air 11" Early 2014 Display Assembly Replacement
But still want to ask about whether folks think I need to do the whole display....
thanks!
par
Ajouter un commentaire
2 Réponses
Yes that guide will work for you, just be careful disconnecting the LVDS connector and with the straps that hold in the airport antenna cables, they can tear very easily. When reassembling make sure the antenna cables are flush inside and just under the logic board, if they aren't you will have trouble getting the display to fit in properly.
Indice 0
1 commentaire:
Awesome. Thanks Plam. Do you agree I need to replace the whole display with that kind of damage?
Thanks!
par
I have LCD issue for the same macbook air, how much does it cost to buy a new one? I called Apple and they are saying they are out of stock for the same, any other source to buy from? Thanks
Indice 0
Ajouter une réponse
Lee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 40
Total : 6,258
