Rear brake light drivers side wont work
have replaced brake light bulbs and fuses and light will not come on on the rear drivers side when pedal is depressed. right side workd
Do the parking/running lights work? Starting with the easiest, I would use a voltmeter to make sure the bulb is good (use the continuity setting), then see if there is power getting to the wire using a volt meter. It's possible a wire got pinched, has a bad connection, or got severed somewhere between point A and B.
Good luck!
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 175
