My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 1,726
