Aller au contenu principal
The Bissell ProHeat 2X Cleanshot is a carpet cleaner designed by Bissell.
Questions au sujet de 10 Voir tout
I need the hose configuration for inside the unit.
I need a schematic of the interior hose configuration, i took it apart to clean & forgot how to put back can you help please?
Répondre à cette question J'ai le même problème
Indice 9
3 commentaires
Please describe(or send a photo of) the area you require guidance and I'll create a tear-down guide for you.
Kind regards
Panshaker Ross
par
I need a hose schematic of a bissell 9200 pro heat
par
Ajouter un commentaire
6 Réponses
Réponse la plus utile
can you show me the hose configuration for inside the unit I took it a part to clean it and can't figure out how the hose go
Indice 3
Here's a picture of the interior of a Bissel ProHeat, I hope this helps
Indice 2
4 commentaires:
No es la misma el modelo mío es 9200
par
I took off the hoses from the front not the back can you send me a picture of the front
par
I think I have a solution for you in the form of a Service Center Guide.
par
I'm in the same predicament! I took off hoses since all were clogged and now I cannot figure out how to put the hoses back together. Is there a schematic somewhere? Its a Bissell ProHeat and the tubing coming from the hose attachment within the case is what I cannot figure out how to reattach and where?
par
Kind regards Panshaker Ross
Indice 1
1 commentaire:
Forgot how to put the hoses together to my Bissell ProHeat complete Pet 2x meet the front of the vacuum cleaner not the back
par
This may help you. There are schematics for hose configurations for several models which are very similar. They do not show the hose configurations for the clean shot nozzle but it is easy to decipher on your own Brain Power.
https://evacuumstore.com/images/proheat-...
Indice 1
2 commentaires:
If you have a Service Center Guide for the Bissell 9500 ProHeat 2X Clean-Shot I would very much like a copy of it myself. I also have this machine and have it working again except after everything is closed back up. Somewhere inside something is binding (suspected) but I can not locate what it is. Any thoughs will also be well taken. Short of a laser leveling device casting a light on the area to get everything below a specific level I am out of ideas. These machines are JUNK was the conclusion I came up with after going inside.
par
Thanks Monty this is the same manual that I found once I sat down and actually started doing my homework, I have the machine back together and working something that the sweeper repair place couldn't do
par
i need hose configuaration for a bissell pro-heat carpet clean
Indice 0
1 commentaire:
Me too. I cleaned the interior hoses that were clogged and now I have one hose that I don’t know where it connects to!
par
Because i took it apart and it took awhile to get the part i need and im a little lost about it
Indice 0
1 commentaire:
My bissel has the indicator that spins on top of the switch s
par
Ajouter une réponse
Pat sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 78
Total : 5,327
