cybershot dsc-w310 is showing only white screen
it is showing a white screen when it is turning on
and no change for further
Sounds like either moisture damage, a loose or bad lcd or bad board. If you are up to it open up the unit and
reseat the LCD back into the ziff clamp and see if that helps. There is a clamp that holds the LCD down and
it may have come loose. Try to reseat the LCD, and while you have the LCD disengaged examine the flex
cable for damage. Keep us posted. If you need a disassembly guide just let me know.
How do you know how to open the camera?
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 52
Total : 5,093
7 commentaires
any answer for this? I also got white screen everytime i turn on the cam.
par evelyn ty
Push down all the buttons at once and push and hold the on -off button until it resets and the white screen should disappear .
It took me a few times,as it's a bit awkward.
par Clifton Jamison
I get a white screen when I take a picture, almost everytime, the odd time it doesn't?
par Karen Rektor
I see the image fine through the screen but when I take a picture, it comes across as almost all white (slight horizontal shading).
How does the reset work? Which buttons should be held down? all of the menu and display buttons on the back?
par Catharine Thompson
If the almost white screen (we call wash out) only happens for pictures then the issue is your lens or settings. Go to main menu/settings/initialize settings. If that doesn't work then you will need a lens replacement because you have a bad iris/aperture.
Question are the lines slightly bent? Do you have any heavy hues like purplish.. etc.. in your picture or is it just washed out?
par Sales Cameraparts4you
Voir 2 commentaires en plus
