Aller au contenu principal
Comment réparer la PlayStation 4, console de jeux télévisés produite par Sony Computer Entertainements, également connue sous le nom de PS4. Annoncée le 20 février 2013 et lancée sur le marché le 15 novembre 2013.
20 questions Voir tout
What are the measurements of the thermal pads and how many?
I'm looking to change the stock thermal padding for the GDDR5 RAM etc. but I don't know the measurements of each piece or how many individual pads I'll have to cut.
It makes me more comfortable knowing exactly what I'll need. No one has this question's answer on Google so you'll be setting the milestone.
Edit. Are there thermal pads covering things other than the RAM? If so, where, how big and how many? Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Solution retenue
These pads are approx. 9mmx9mm you can just make them 10mm x 10mm though since there is plenty of room to make them bigger.
Here are a few pics.
Indice 11
9 commentaires:
Thanks for the answer! Do you know how many 10x10mm pieces there are? Are there any pieces that are different measurements? If so, how many?
par
There are 8 on the top side and 8 on the bottom side. There are no other thermal pads on this motherboard.
par
I'm looking to do this as well but doesn't the thermal pad need to be the correct thickness ? I'm guessing something like 2 mm would do but I'm not sure.
par
They are 1mm.
par
Thanks for the reply by the way, I just got around to opening up my ps4 and I'm glad I did. Three of the factory thermal pads were hardly even on the memory chip, they were off to the side touching the motherboard like it was slid into place rather than placed down. Also it had way to much thermal compound on the apu. It was a mess.
par
Voir 4 commentaires en plus
Hi Alex
I just teardown my PS4 which is CUH-10XXA on 07/29
Don't know is it too late to share this information with you.
At the beginning I use 2.0mm to replace the thermal pad, and then I turn on my PS4,
but the height is too high so the APU can not touch the heatsink with 3 beep
After that, I use the 0.8mm instead of , so far the machine is ok.
Indice 1
2 commentaires:
I am searching through the web, still cannot find any leads for the thickness except for your post. I am changing pads on my PS Pro. Do you think 0.1 cm or 1mm works?
par
.8mm on the side with the APU, as pictured above, .8mm-1mm on the bask side of the board that doesn't have the APU.
par
Does anyone know what the power dispersion W/mK should be for PS4?
Indice 0
Ajouter une réponse
Alex Fung sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 22
30 derniers jours : 131
Total : 28,282
