Aller au contenu principal
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
Questions au sujet de 23 Voir tout
charge in car with inverter
Is there any reason a driver with a jump starter power station could not use an inexpensive (read modified sign wave) inverter to keep a jump starter topped off. Mostly I need to know to use this to power a CPAP. I know this will use more power than a straight cable, but the indicator lights work with AC
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
it should work as long as the wattage of the jump box is less than the normal output of the inverter. Also, make sure you are running the engine when using the inverter as it will drain your chassis battery.
Indice 1
Ajouter une réponse
andre sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 1,054
