Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'Optoma HD20 est un projecteur home cinéma d'une résolution de 1080p, sorti en août 2009. La réparation de cet appareil nécessite des tournevis et des outils de levier.
Why is my device constantly overheating?
Lately, my Optoma HD 20 has been getting really overheated a few minutes after powering up. It hasn't always had this problem. I just noticed it recently. What should I do?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
Your device may be overheating because the fan is dirty or the fan is broken. You filter may also be clogged and dirty which is preventing the fan from running correctly which results in overheating.
Indice 3
apart from the fans , u also need to double check the qulaity of the lamp that you replaced lately [ if you have ]
if yes , then thats the answer to ur problem!
try and get a genuine lamp, will save ur projector's optical engine in the longer run!
Cheers
Indice 0
Ajouter une réponse
Jacob Cope sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 24
Total : 5,477
