Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone Samsung Galaxy Alpha est sorti en septembre 2014 et est également connu sous le nom de Samsung Galaxy Alfa. Il fonctionne sous le système d'exploitation Android et est proposé par la plupart des grands opérateurs de téléphonie mobile.
Why won't my phone turn on!
Why won't my phone charge even when I plug it in?
I took my phone into the bathroom with me and now it won't work.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
3 commentaires
Can i just tell you my friend that i have just experienced the same problem. My Galaxy has given up after just three months from new. Not even been offered a rereplacement but a repair. Obviously there are problems with this product
par
Mine aswel wont charge .. after using it for 9 months .. i charged it 2days ago. But last night I was trying to charge it before I go to bed but it wont charge till this moment., am so so confuse right now.. any help pls.
par
change the ic power (MAX77804K )
par
Ajouter un commentaire
1 Réponse
Solution retenue
Your phone probably has water damage. Sometimes the steam and condensation from a hot shower can get into your phone. If you open up the back panel of your phone and pull out the battery you will see a small square on the inside of the phone, if this square is white then your phone does not have water damage, however if the square is pink then there is water damage to your device. Another one of these strips is located on the bottom of the battery. Even if the strip on the phone is white, then there could still be water damage to your battery, if the strip on the bottom of the battery is pink, then there is damage. This may be the source of your charging problem.
Click Here
Indice 4
2 commentaires:
Nope that isn't it nice try though.
par
my 4ne just wudnt charge so bought a new cable but still doesn't charge cant understand why? please help as my 4ne is turned off
par
Ajouter une réponse
Tyler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 16,007
