Why won't the microphone pick up sound?
The headset and adapter are plugged in and I can hear game and chat sound, but no one can hear my voice from my microphone.
Have you checked to see if the mute function is activated? Make sure that the microphone is not muted by pressing the mute button on the adapter.
It's also possible that the headset is not completely connected to the adapter, or the adapter may not be fully connected to the controller. In this case, the speakers would not be working as well.
If these suggestions did not solve the problem, check out the troubleshooting page.
None of these steps worked for me. Found this YouTube video that was an easy fix with the power settings. I don't understand why, but here ya go https://m.youtube.com/watch?v=sTlNv26Wgc...
Well done . It fixed my daughters headset problems . Thank you for sharing this link
My son is having opposite issue, he can hear everyone but they can't hear him. Headset works fine through computer. Any ideas whats up?
We tried all sorts bought a new headset, following the instructions on the new head set ended up finding a setting that I didn't know existed, turned it on and hey old headset now works!
1 Go to settings
2 Kinect and devices
3 controller
4 other options
5 volume
6 at top of list is a button to turn mic on
turned it on and and it worked!!
We had never turned the mic off, it just stopped working overnight.
The 30quid for new headset was not a waste as wouldn't have found that setting without it!!
Thank you I was trying to fix this for hours ended nearly tearing my mic controller and console to bits to find it but this was all it was ty. I do feel like Microsoft should find a way to fix that cuz I sure as !&&* didn't do it
Yo @claireyb . Big up you. You fixed my headset. Many thanks
This works don’t even try anything else if this is the problem this is the solution.
Thank you!! You fixed our problem! :)
I have this issue however the volume part is grayed out and won't let me click it! I'm so frustrated and I know it's definitely not the headset or controller as they've been tried and tested but it still persists. It's 100% a setting and just stopped working randomly after an update! Tried everything I can think of :(
This worked for me -
Settings
unplug headphone
controller settings with pic of controller on
click Buzz handset buzzes
click firmware update even though not required
shows 100% and complete
Plug headphone back in and it worked
I can talk but I can't hear any sound on my headphones
BRO YOU ARE AN ACTUAL GOAT, ITS ACTUALLY WORKING <3 much love bro
THANK U. Woked for hours trying to find out y they werent working.
I couldn’t hear any sound in my headset and thought it was the mic and I connected it to a different controller and it worked.
Check that the controller is charged, and headset has power. Click the microphone mute button on the headset adapter to be sure mute setting is off. The Xbox One controller's firmware may need to be updated.
If problem persists, see the troubleshooting guide: Xbox One Stereo Headset Troubleshooting
I had this issue with one of my controllers. Connected via a USB cable to the xbox and force updated the handset firmware under devices in settings. Problem solved. HTH.
A great way to solve this problem is to do these steps
xbox accessories
more options
update your controller.
xbox accessories
more options
see if the mic option is on.
If none of this works then it is your controller so change controllers then if that does not work your headset is broken.
Does someone have an updated version since the new console update moved and renamed alot of settings. (Ive tried all controllers and headsets) my issuse is that I can hear all noices although for some reason I cant talk to others “I've checked my mic to make sure it's not muted" it was working just fine yesterday, then when I go to wake up and use it… it doesn't work. Although if I go to the party and mute then unmute, my pfp lights up a for split second indicating that my mic is making sound, but then it stops and I cant speak but I can hear stuff. Pls help I legit cant find any fixes and all the answers here are useful for the old xbox settings arrangement.
Ps: I've got 3 controllers and 2 headsets, 1 controller is the [default], 2nd is a [PDP] controller, and last is a [PowerA]. (Both headsets are wired)
Dernières 24 heures : 5
7 derniers jours : 20
30 derniers jours : 74
Total : 560,693
23 commentaires
I have the same problem, It looks common for the Mic piece to function fail.No updates,batteries are needed.
par KeyBrute89
I have this problem with my old 360 headset that's plugged in using the chat adapter
par Harry Whitehead
Try this it worked on mine. Recently...Today actually...
MIC FIX: http://preview.tinyurl.com/j4fjuuo
par christina harrison
If you have an xbox one controller like me, you may discover that the gadget that plugs into your xbox with the bolume controls on isnt working OR the slot it goes into isnt working. Try taking it off and if your mic has a single phone socket that normally goes into it just plug it into the phono whole that you can see after you remove the gadget. I discovered my controller slot inside was broke and needed to use phono socket
par greatbigmassive
I have tried all methods on YT can't find a single one that works but i did find a good vid on it so try this one out:
https://www.youtube.com/watch?v=OG9j3k-_...
par Toxic Pie
Voir 18 commentaires en plus
