white MacBook won't come out of sleep /hibernate
In last 2 weeks I was able to turn it on twice by just pressing the power button my last session was still in memory. browser was up
battery is fully charged, ac adapter plugged in.. i can hear the humming but nothing on screen and keyboard doesn't work. white light is solid. I have done all kinds of resets. Last time It came back on i changed the power setting to never to stop either hard drive or display but still it went back in sleep mode and pressing power buton does nothing. here is few lines from log i collected last time it decided to wake up.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Contrast.monitorPanel/Contents/MacOS/Contrast and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/TVOptions.monitorPanel/Contents/MacOS/TVOptions. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/TVOptions.monitorPanel/Contents/MacOS/TVOptions.
Jun 18 13:53:17 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: Can't access "efi-boot-device" NVRAM variable
Jun 18 13:53:31: --- last message repeated 3 times ---
Jun 18 13:53:31 arifs-MacBook configd35: arp_client_transmit(en0) failed, Network is down (50)
Jun 18 13:53:31 arifs-MacBook configd35: bootp_session_transmit: bpf_write(en0) failed: Network is down (50)
Jun 18 13:53:31 arifs-MacBook configd35: DHCP en0: INIT transmit failed
Jun 18 13:53:31 arifs-MacBook configd35: DHCP en0: ARP detect ROUTER failed, arp_client_transmit(en0) failed, Network is down (50)
