Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le cinquième téléphone Nexus de chez Google. Officiellement annoncé le 31 Octobre 2013, il arbore un écran de 4.95" en 1080p, un processeur Snapdragon de 2.26 GHz et est compatible avec le réseau LTE. Fourni avec Android 4.4.2, KITKAT. Manufacturé par LG.
Bootlooping because of power button
There's a common issue with N5 where the power button causes the phone to bootloop. I've stripped it down, but I'm unsure what to do with regards to fixing this issue. I've been quoted £30 to fix the power button, but I'm not sure if this will fix the issue.
Répondre à cette question J'ai le même problème
Indice 11
Ajouter un commentaire
3 Réponses
Réponse la plus utile
The problem is with the physical button on the motherboard, which is just not so well designed, because dirt can get stuck into it.
Remove the motherboard from the unit, and blast some rubbing alcohol into the actual button part with an air duster. Wait until the board is entirely dry and reassemble. I have to do this every couple of months, it's a bit of a drag.
Indice 2
I temporarily fixed mine by button bashing the power button until the phone rebooted. I felt pretty stupid doing so but after about 20 seconds of really fast clicking on it quite hard it worked. I already tried replacing the battery twice since boot loops are often caused by power issues but without result. Anyone know a solid fix? Is it the button on the logic board that has to be resoldered?
Indice 1
1 commentaire:
I have the very same problem. I really don't know what to do.
par
Saskia's answer above is the best solution short of replacing the part (i.e., replacing the motherboard, in most cases probably more hassle/expense than it is worth).
One quick and dirty, no-disassembly trick that worked for me several times was to rap the phone (in a bumper case) sharply against the edge of a counter with the power button facing down). Optional followup: with the button still facing down use the crevice tool (with the case off) in hopes it would catch anything that had worked lose in the thin gap between the switch and the phone body.
Not ideal but handy if you are on the road and want to give it a try.
Indice 0
Ajouter une réponse
Liam Cooper sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 3,828
