Why is my samsung galaxy 12.2 inch keep blinking?
Every time my samsung galaxy pro 12.2 is on low battery it will start blinking a lot it will also do it randomly. It also won't keep a charge if it's on 100 percent it will jump to 20 percent really fast. It is also new so I don't know what the problem could be?
21 commentaires
Yeah my Samsung Galaxy tab 4 starts flickering so much that you can't even see the screen and it turns black and white but sometimes the flickering is not so bad that you can see the screen
par Jo D
Open the back of of your tab4 unplug the battery and press the power button then plug the battery back in and close it up restart it and problem solved . I found out its a charging issue it messes wuth the battery but this procedure fixes it . Hope it helps Cheers
par lvcarsalesluigi
Hope this works - I will try as soon as my problem get so bad I have too do the surgery on my tablet.
par ahanson51
Did it work?
par philhale2
Last night after months of not doing the flickering it started back up so after an hour of it acting up i decided to do the battery trick were i pull of the back cover and rest the battery by simply unpluging it and pressing the power button and then reattaching the battery and it fixed it again no more flickering.
I guess something happends were the battery gets messed up in the charging cycles cause when i was about turn it off to do the procedure the battery was at 27% when i re-plug it in and restarted 42% so something is up with the battery charging system in android or on the battery itself ,good thing is i now know what fixes it for sure i hope this helps someone else.
par lvcarsalesluigi
Voir 16 commentaires en plus
