Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Super Nintendo Entertainment System (SNES), ou simplement Super Nintendo, est une console de jeu 16 bits lancée par Nintendo en 1990. La Super Nintendo était l'une des meilleures ventes de son époque et compte encore aujourd'hui beaucoup de fans.
Every button pauses the game!
Ive tried several controllers on my super nintendo and every game all the buttons pause the game. up, down, left, right, a, b, everything pauses the game. it is the console, how do i fix it?
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
I have the same exact problem. It can't be that uncommon but I have not found an answer.
par
Hi, I'm having g the same issue, it's 100% not the controller ports as I've swapped them out with a mates and same issue persists. player 2 is unaffected.
I'm going to look at the motherboard later last I'm running out of ideas, hoping it's something simple like dirty trace or capacitor gone.
par
Ajouter un commentaire
3 Réponses
Your controller port is busted. Check the pins they may be corroded. Try to clean the pins first with rubbing alcohol or compressed air. If that does not work you will need to replace the controller ports and pins.
Indice 0
1 commentaire:
I tried swapping the controller port as well and it didn’t work. Did anyone find a fix for this yet?
par
That's usually caused by the flat cable that goes from the controller board to the motherboard. All you have to do is either replace it or remove it and solder wires for each trace instead. Some good old cleaning with some IPA will sometimes be enough tho.
Indice 0
What you should do is Open it up. Clean the contacts with some isopropyl alcohol. And it should work !
Indice 0
Ajouter une réponse
SimonFett sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 32
Total : 3,220
