Touch not working after new LCD install
I am a professional cellphone repairman and this issue has me perplexed. I bought an entire frame/lcd/digitizer replacement combo and very carefully transplanted all the componets. When I powered on the device the touch was not working. I figured the part was defective so I reinstalled the old LCD/digi/frame and now the touchscreen does not work on that either! There is only one cable that plugs in to the main board for both the LCD and Digitizer and I have absolutely made sure it is completely plugged in. HELP!
2 commentaires
Hi Daniel,
I also had the same problem identical to yours, but I can't find out the problem. I have done hard reset with the keys in addition to reset and update with windows device recovery, but getting no positive result.
Are you solved the problem?
thanks
Dave
par starcruising
Same issue here with nokia lumia icon. The different screen voltage requirement should be published better. I paid 82 bucks for the new screen and frame assembly. I'll try to return it for the right one.
par jonmackiesr
