Why does my netbook shut down after 2 seconds?
Hi,
I`d firstly like to say that I have read most of the other questions that relate to the above and I have tried the suggestions (alas) and am currently in the process of trying the following...(the actual problem is the netbook shutting down after just a second or two...no time to get into the BIOS before shutdown)
I have taken off the keyboard etc and have removed the touchpad surround so I have the motherboard and internals etc facing me...I did this in order to check the DC connector but all seems fine...I then connected the mains lead without the battery connected but no light came up..ie,no power...I then re-connected the battery and mains lead and I have a power light showing that it is connected...
What I would like to ask is does this mean that the motherboard is ok or could the motherboard still be the problem ?
Hope you can help...thanks,
Etiennette
1 commentaire
I have found that with both mains connection and with the battery I can get the netbook to turn on but it shuts down again after about 2 seconds...fan is running when turning on.
par Etiennette
